^^ When i found out it was under the intake mani instead of the fire wall i (-‸ლ) a little bit...
Removed Fan clutch and shroud.
NOTE: ANY ONE WITH AN ORIGINAL FAN TO CHECK YOUR FAN/ SHROUD EVEN IF YOU THINK ITS GOOD!!
Even though my shroud appeared fine from the top, once removed you could see the damage done. Luckily The fan won and the shroud lost!
Nasty long over due coolant flush!
Old thermostat has seen better days
Lower temp Themo installed
Fan switch looked as bad as the thermo
New Fan switch
Cleaned and painted the thermostat housing.
Royal purple , Filter & Degreaser to try & figure out where my leaks are coming from!
Degreased and Painted oil filter housing
Latest problem
= Code 1286 and Gauges going crazy!
Started by checking knock sensor since i just replaced one wanted to make sure it was snug.. it was.. next checked grounds.. Bingo bad ground, 1286 is gone but the gauges are still going crazy maybe bad cluster or dme? any thoughts?
Next, time for a little weight removal.
Fan clutch / shroud = heavy as hell and removed
Interior floor mats = removed (3LB)
Stock Airbox with filter (3lbs 5oz)
Jack = Removed (5lbs 2.4oz)
High Beams (1lb 10oz for pair)
r. speakers (pair) (5 lb 1.7oz)
-tools/amp/antenna (7lbs)
Trunk carpeting = removed (17LB)
Heavy Spare= removed (33lbs) (NOTE: In e36 convertible's the spare acts as impact absorption/deflection! if removed and you have a rear collision you will sustain much more damage then if the tire was there!)
6 disk cd changer = A Brick & Removed. Good by Tunes, Hello Power to weight Ratio! (10Lbs)
Windsheild washer Bottle and pump (10lbs.) are the last to go for now, but I have my eyes on the back seat
and to replace with some kind of carpet solution.
Total weight removed Around 105lb Give or take a few pounds.
