Author Topic: Hello need help Please!!!  (Read 2535 times)
nozkrazy
« on: November 23, 2013, 04:14:46 PM »
Hello new to the forums
umm need help identifying what went wrong???
i was driving on the freeway to work, like ususal..
and halfway there BOOM sounded like something poped and lots of rumbling
got out and i could see fire coming from the cat... towed it home later that day
bigskyis
Re: Hello need help Please!!!
« Reply #1 on: November 23, 2013, 05:11:25 PM »
I could be wrong...but looks to me like you are in the market for a new engine. Looks to me like you punched a hole in your block.
nozkrazy
« Reply #2 on: November 23, 2013, 05:16:00 PM »
Yea that's what I was thinking :( it's look like a head punched through my block
mabeer
  • -Receive: 8
« Reply #3 on: November 23, 2013, 05:29:21 PM »
Sorry for your misfortune.
Wake74 has one for sale in the For Sale Forum
I am pulling the M42 out of my 318ti for an M52 swap. This car is my daily driver. Engine runs strong, no known issues.
New parts since I have owned the car, since July:
  • Mobil 1 in engine, Redline in tranny, BMW coolant
    New belts
    New idler pulleys x 3
    New plugs
    New water pump
    New plastic coolant pipe
    New thermostat
    New vacuum hoses to / from ICV
    New vacuum hoses to fuel injectors
    New flow matched fuel injectors
    New motor / tranny mounts
Things that will be sold with the engine:
  • Long Block
    All bolt-on accesseries, AC compressor, alternator, power steering pump
    Intake including the sought after M42 intake
    Exhaust manifolds. You can have the cat section too, but the heat shield is loose, needs to be removed
    Engine wiring harness
    DME
    Transmission & Clutch
    Engine mounts
I also have a manual tranny 328 (my engine donor) wreck that you could pull the clutch pedal, etc. from if you are trying to do an auto to manual tranny swap at the same time
Will include a few misc. M42 parts, extra ICV, intake boot, MAF, intake gasket, etc.
Have not attempted to dress-up the engine, or make the engine shiny. This is exactly as driven photos.
Asking $700 cash picked up in Lakeland, FL for everything. Lakeland is approximately half way between Orlando and Tampa, FL.
Videos:
http://www.wakefieldweb.org/BMW%20E36%20Parts/IMG_0770.mp4
http://www.wakefieldweb.org/BMW%20E36%20Parts/IMG_0769.mp4
« Reply #4 on: November 23, 2013, 05:59:58 PM »
+1 - sorry to hear about your motor.
There is a "silver lining" though - You'll be able to get some of that money back if the cyl. head is still good. If you're lucky, the piston stayed low in the bore and no valves were bent.
Heads are hard to find since most M42s die by overheating. They usually go for $250 or so around here.
colin86325
« Reply #5 on: November 25, 2013, 07:41:54 AM »
I had that happen to me: boom sound, huge ball of fire coming from under the car as I was driving on the freeway, and a huge hole in the engine block.
I spun a bearing and the rod and piston exited the block.  Not fun, but I was able to build a decent new motor that's a lot of fun.
