Author Topic: how work ect with 1 wire on a 318IS 91  (Read 5027 times)
bimmer91
« on: November 15, 2013, 08:46:16 AM »
hi i'm a new member and i have a problem with my 318IS 91.I dont understand how the ground work on my ect sensor.In the bentley shop manuel i have2 wire on the etc sensor but on my car i have only 1 (brown and red).how the ecm take the return signal ???
Thanks a lot for reply.
Re: how work ect with 1 wire on a 318IS 91
« Reply #1 on: November 15, 2013, 10:24:27 AM »
Coolant temp sensor?  There are two - the single wire goes to the coolant temp gauge. Look for another one right next to it, that's the DME sensor.
bimmer91
« Reply #2 on: November 15, 2013, 12:17:55 PM »
tanks a lot
i will stop to loose my time on the single wire coolant temp. sensor
« Reply #3 on: November 15, 2013, 03:04:09 PM »
Sure thing.  There is no signal on that sensor - it's just resistance. It'll have high resistance when it's cold (> 6K Ohms), dropping down as it gets hotter.  Fully warmed up it should only have 100 ohms or so.
