Author Topic: E36 m42 into e30 wiring problem  (Read 3255 times)
OfirAs
« on: September 28, 2013, 10:32:33 AM »
Hi,
I swapped my m40 to m42 from e36.
I took the engine from e30 that was with m10.
In the c101 connector everything is ok
The fuel pump is not working, when i connect it directly it fine.
And also i dont have spark.
What could be the problem?
Any direction could be helpfull.
Thanks,
Ofir.
Re: E36 m42 into e30 wiring problem
« Reply #1 on: September 28, 2013, 08:17:13 PM »
Might be Bosch's EWS protection.  If so, you'll have to clip a wire on the DME harness to get the motor to start.
OfirAs
« Reply #2 on: September 29, 2013, 04:21:13 AM »
One more problem is that the ECU is getting hotter when i connet the battery and the switch is off.
How can i find the EWS protection on the harness?
The guy that i took the engine from him told me that he bought harness without this protection.
Thanks alot for the help.
