Author Topic: Oil Filter Housing  (Read 4537 times)
ti_tony
    • Elvis
Oil Filter Housing
« on: June 28, 2013, 06:09:03 PM »
I'm changing the o-ring and paper gasket out and having trouble finding the torque specs for the 6 bolts. I did a search and found a lot of good threads on the subject but no specs on the bolts, anybody have those?
colin86325
Re: Oil Filter Housing
« Reply #1 on: June 28, 2013, 06:30:27 PM »
They might be listed in the factory torque manual:
http://www.bmw-m.net/TechData/torq/bmw_torq.pdf
ti_tony
    • Elvis
« Reply #2 on: June 28, 2013, 07:52:07 PM »
Thanks for the link, I found the oil filter housing but it calls for 8mm bolts and mine are 6mm. I'll use the specs on page 4 for 6 mm. In the table they list
   m6 thread                m6  8.8    9.9Nm
                                 m6  10.9   14.0Nm
                                 m6  12.9   16.9Nm
I'm not sure what the 8.8  -  10.9  -  12.9  stands for? I suspect strength of material, higher number more torque?
Page 37 is the page I'm looking at with the oil filter housing.
deansweet
  • -Receive: 12
« Reply #3 on: June 29, 2013, 01:10:03 PM »
Torque specs are 7.1 FtLbs/89 InLbs on the housing.
ti_tony
    • Elvis
« Reply #4 on: June 29, 2013, 07:20:03 PM »
Thanks deansweet, I've got everything cleaned up and should be able to put it together tomorrow.
colin86325
« Reply #5 on: June 30, 2013, 06:40:51 PM »
The 8.8  -  10.9  -  12.9 numbers refer to the hardness or strength rating for the bolts.  The number will appear on the head of the bolt.
ti_tony
    • Elvis
« Reply #6 on: June 30, 2013, 08:34:15 PM »
Thanks colin, I found this site last night        http://euler9.tripod.com/bolt-database/22.html      I'm use to slash marks and "grade markings"
  I got the housing back together and changed the o-ring on the oil dip stick and everything is nice and dry.
