Some of you might remember I bought another 92BMW318is, this one leaks a little antifreeze. When I bought it I picked it up from a towing company that told me it wouldn't start, and it has been sitting there for around 6 months. So I had it Towed to my house and checked all the fluids there was really no antifreeze and there was too much oil (oil did not appear milky). I drained the oil and put antifreeze into it, turned it over and it started right up. Soo, now I have to get it e-checked.
But when I go to accelerate it stutters and doesn't want to go, until I give it more gas then it should take to get to second gear, when in second gear it does the same, it stutters/stumbles and makes this bellowing noise for a second at a time.
-Only occurs when I switch gears and accelerate,
-Does it on every gear,
-Doesn't do it if I'm coasting with my foot slightly on the gas.
-Check engine light comes on when idling and goes off when i accelerate
-Stomp test says I need a new o2 sensor.
Any ideas?
