Author Topic: Cam question..  (Read 3050 times)
bme30
Cam question..
« on: May 30, 2013, 08:11:18 PM »
So in addition to my itbs i was thinking about upping the compression with the m50b25tu piston and the MM sport cam.
Im wondering if I should just install the cam and not bother with higher compression.
Would i see a decent gain with the itbs MM sport cam with tuning?
wazzu70
  • Nasty Nick
  • -Receive: 18
Re: Cam question..
« Reply #1 on: May 31, 2013, 11:04:37 AM »
Yes, the cam and tuning are the best ways to unlock power. With ITBs I would consider a more aggressive cam though to get the most benefit.
If you are unhappy with this, you can always upgrade pistons later :)
-Nick
91 E30 M42 with VEMS
bme30
Cam question..
« Reply #2 on: May 31, 2013, 12:52:02 PM »
Sounds good!  Ill check out other cam options.  But i dont want to go too wild as i dont want to loose too much of the low end.
Thanks
wazzu70
  • Nasty Nick
  • -Receive: 18
Re: Cam question..
« Reply #3 on: June 01, 2013, 10:26:22 AM »
VAC 269 deg cams seem to be a nice aggressive cam thats still streetable. You could also try contacting Paul Burke to see if he can do M42 cams. Best way to contact him is through Miller. https://www.millerperformancecars.com/home.html
-Nick
