Author Topic: Is the air flow meter necessary?  (Read 3064 times)
CMPLX01
  • 1995 318 is
« on: May 12, 2013, 04:42:58 PM »
So ive herd somewhere that the airflow meter can be taken out. but doing so would mess with the computer..  how do i throw it out with affecting performance?
MLM
  • -Receive: 10
    • My M42 ITB Project
Re: Is the air flow meter necessary?
« Reply #1 on: May 12, 2013, 07:47:54 PM »
On a stock ECU you need the AFM, There has been no sucessful conversions to non afm on the stock ecu to my knowlege using MAF and chips etc though there are some working on this.
To throw out the AFM 'just' throw in an aftermarket ecu and retune from scratch.
« Reply #2 on: May 13, 2013, 10:45:11 PM »
You cannot remove any stock sensor and expect the thing to run properly. The AFM does not hurt performance on an internally stock engine either, so there is absolutely NO reason to want to remove it. Period.
