Author Topic: New alternator not charging  (Read 3389 times)
Uniquestrain
« on: May 03, 2013, 01:34:30 AM »
Hi everyone
I recently put a "new" m42 engine in my e30 and ive been having problems since then
When i wired everything up it started up but would die out after a few minutes, got so bad it wouldnt start.
I noticed my fuel pump wasnt turning on so i jumped the relay and now fuel pump turns on.
Guess that wasnt the problem cause it keeps turning off, i tested my alternator to see if it was charging and it wasnt so i went and bought a new one
Still nothing...im wondering if i connected something wrong or if my engine harness is bad
romkasponka
Re: New alternator not charging
« Reply #1 on: May 03, 2013, 04:39:43 AM »
Is your engine ground cable connected?
E30 318is M42
E36 318is M44
Uniquestrain
« Reply #2 on: May 03, 2013, 11:17:18 AM »
Passenger side of the car is not the one next to the alternator
Can it be that ground? And if so where can i connect it to?
« Reply #3 on: May 08, 2013, 07:08:39 AM »
IIRC the stock E30 ground strap bolts between a stud on the passenger side inner frame member and the right motor mount arm.  I'd also be inclined to put a big fat wire off the alt mount bracket or bolt to the driver's side grounding block.
