Author Topic: M50 E36 Turbo Manifold + T04E Kit M42 conversion? low budget  (Read 10684 times)
Vandice
So i was thinking of a budget Turbo Build i already got the KDFI v1.4 (ms2 based PnP Megasquirt) and the AEM Lambda Control
My opionion is cutting the M50 Manifold to fit M42 Head like this
Can anyone give me some infos about the Turbo? huge Turbo lag? will run it about 10psi on E85 Fuel , 440ccm Injectors
Vandice
Re: M50 E36 Turbo Manifold + T04E Kit M42 conversion? low budget
« Reply #1 on: May 03, 2013, 02:28:55 PM »
no one?
wazzu70
  • Nasty Nick
  • -Receive: 18
« Reply #2 on: May 03, 2013, 04:10:20 PM »
The question is hard to answer. What trim is the turbo? There are a few different versions. Is it ball bearing or not? Genuine Garrett or not?
The turbo will be fine for your motor as it has the T3 turbine which is great for a 4cyl. If you are running E85 you could run a lot more boost than 10psi.
This turbo, depending on trim is a high 300 to mid 400 wheel hp turbo
-Nick
91 E30 M42 with VEMS
fumstoo
« Reply #3 on: May 03, 2013, 05:46:54 PM »
Not with those injectors. The thing with e85 is you need way more fuel so If youre going that route you need much bigger injectors. Maybe go meth instead
Vandice
« Reply #4 on: May 04, 2013, 08:23:14 AM »
good to know any suggestions?
this Turbo Manifold kit seems pretty cheap
http://www.ebay.de/itm/T04E-TURBOCHARGER-W-IN-WASTEGATE-TURBO-MANIFOLD-92-99-BMW-E36-325-328-323-M50-52-/190648333773?pt=Motors_Car_Truck_Parts_Accessories&hash=item2c6386b5cd
Compressor:
Trim:   57
A/R:   .53
Inducer:   50.55
Exducer:   76.00
Turbine:
Trim:   58
A/R:   .63
Inducer:   65.20
Exducer:   56.06
how much psi can you go with stock compression?
cheers from Germany
« Last Edit: May 04, 2013, 08:25:19 AM by Vandice »
fumstoo
« Reply #5 on: May 04, 2013, 10:06:46 AM »
umm... No one knows.. But you can find out  :D Your limit right now is if you dont plan on getting head studs and an mls or o-ringing the block. Other than that theres no reason to believe that you cant safely run 15psi. Yeah, theres high compression but so are most of todays turbo cars.  The tune will be your key. Do you have a good tuner?
You can find injector calculators online. Im not positive but I would think youll need atleast 800cc.
Vandice
« Last Edit: May 04, 2013, 08:24:13 PM by Vandice »
wazzu70
  • Nasty Nick
  • -Receive: 18
« Reply #7 on: May 05, 2013, 12:01:04 AM »
Whatever injector size you need with petrol, multiply by 1.5 to get the size you need with E85 with a little headroom.
I can't really recommend any of the ebay/china turbos. I suppose if you do look for a GT2871R knockoff.
-Nick
