Author Topic: M42 feels like it hits 4k rev limiter when it gets hot  (Read 2578 times)
sbarton
    • Duct Tape Motorsports - LeMons/Chump Endurance Racecar Rentals
« on: April 24, 2013, 02:56:26 PM »
I've got an M42 swapped into a 1874 2002tii.  It runs fine when cold, but when it gets hot after running hard for 30-60 minutes it feels like it hits a rev limiter at 4000-5000rpm and get worse if I continue to drive it,  If I let the car rest for a bit and cool off, it is fine again.
I've swapped the ECU, Coil Packs, AFM/MAF, and even the entire motor with engine wiring harness.
I'm pretty sure it is electrical since it only happens when it is hot.  Any ideas/suggestions?
Thanks!
-Scott
« Last Edit: April 26, 2013, 10:19:02 AM by sbarton »
wazzu70
  • Nasty Nick
  • -Receive: 18
Re: M42 feels like it hits 4k rev limiter when it gets hot
« Reply #1 on: April 24, 2013, 04:13:05 PM »
I agree it sounds electrical. I would check all your sensors to verify they are working properly. The testing procedure for most of the sensors is in the bentley.
I would check crank and cam sensors, coolant temp, throttle position and AFM/MAF to start.
-Nick
91 E30 M42 with VEMS
sbarton
« Reply #2 on: April 26, 2013, 10:18:21 AM »
Problem is that the all sensors are on the motor and I swapped motors.  So essentially different sensors, same issue.
-Scott
wazzu70
  • Nasty Nick
  • -Receive: 18
« Reply #3 on: April 26, 2013, 11:40:07 AM »
That does not mean all the sensors are goving the correct signal though. Did you change wiring harnesses as well?
-Nick
