Author Topic: What Happens With a Stuck Timing Chain Tensionser?  (Read 2285 times)
ClayW
« on: April 22, 2013, 11:24:41 AM »
I disassembled my poorly running M42 and found that the timing chain tensioner was stuck. I had to force it out from the inside with a screwdriver. As I understand it, it should slide freely, right?
What problems might this have caused?
Project Blogs:
1967 BMW 1600 w/M42: www.tx02.blogspot.com
1991 BMW 325i DD: http://www.r3vlimited.com/board/showthread.php?t=266953
colin86325
Re: What Happens With a Stuck Timing Chain Tensionser?
« Reply #1 on: April 23, 2013, 11:06:53 AM »
Weird.  Yes, it should have extended on its own once it received enough oil pressure.  It was probably either faulty or somehow installed such that it did not get enough oil pressure (??).
Check your cam timing to make sure the chain hasn't jumped timing.
ClayW
« Reply #2 on: April 23, 2013, 01:11:30 PM »
I discovered this as I disassembled the engine. I'm trying to figure out why it was overheating. Anyway, a new engine is almost ready to go in.
Project Blogs:
