Author Topic: brake booster check valve?  (Read 3482 times)
AutoXSS
« on: April 20, 2013, 03:48:09 PM »
Looking on realoem and can't find it. Anyone know a part number to find one? Can't find it at pelican either....
Re: brake booster check valve?
« Reply #1 on: April 20, 2013, 04:53:52 PM »
It should have a part number somewhere on the part itself.  I couldn't find it either...odd, isn't it?  I'll bet it's the same part as the other cars with the same braking system.  IIRC the M42 usually has an Girling system.  Look for it as a "non-return valve" as well, seems like an odd German translation.
deansweet
  • -Receive: 12
« Reply #2 on: April 20, 2013, 06:45:03 PM »
It's a bit further away than yours is but here it is on our '91 318is.
$pendy... Part #13, non-return valve, $68.89
http://www.realoem.com/bmw/showparts.do?model=AC95&mospid=47277&btnr=34_0700&hg=34&fg=25
AutoXSS
« Reply #3 on: April 21, 2013, 10:14:47 AM »
Do you guys have it connected three ways? Mine is only spliced between the brake booster and the manifold
