Hey guys,
You may or may not have read my previous post wondering if Supertech was a reputable company to buy from. Well after Wazzu informed me they are a well known and trusted company, I decided to use their products to rebuild my head.
So I have sitting here 8 Exhaust valves (BMEVN-1030s) and 8 Intake valves (BMIVN-1030s). Upon unboxing these the first thing I noticed was the stem diameter seemed smaller then the OEM Valves, I wasn't aware of this when ordering, shame on me for not asking enough questions. I went to the toolbox and grabbed the micrometer and sure enough these valves are 5.969mm stem diameter appose to the 6.959mm valves I removed.
I'm guessing these valves would be used with a 12.56 x 6mm valve guide then?
Like these:
http://www.rmeuropean.com/Part-Number/Valve-Guide---IntakeExhaust-1st-Replacement-(1256-X-600-mm)-__11121735533_CAN_BA4EBA02.aspxWhat is the purpose of using smaller valve stem diameter? I would Imagine maybe for gains is flow, but surely these would be very very minimal.
EDIT:
After doing a little research I now see the later E36 & Z4 M42/M44 seems to be using this valve stem diameter. Will I have any issue using these valves with the above guides? I'm pretty sure I wont but its always good to get a 2nd opinion.
