Author Topic: vdo oil pressure  (Read 3383 times)
redhead
vdo oil pressure
« on: December 28, 2006, 04:57:54 PM »
I have an m42 engine and was wondering hat vdo sender (part #) you are using for an oil pressure guage and to have the idiot light working as well?
Thanks gang,
Gene
Vladi
    • http://www.bmwzone.ro/forum
vdo oil pressure
« Reply #1 on: December 29, 2006, 09:37:15 AM »
The light from the gauge?
billb
Here's the parts list from when I did it in 2005...
« Reply #2 on: December 29, 2006, 10:04:37 AM »
Quote from: redhead;16385
Thanks gang,
Gene
This is the body of an email I received from http://www.gaugeman.com:
Hi Bill -
My GMOP2 adapter was designed just for that purpose - it's "Y" shaped with 2 outlet ports (see website). One of the ports is threaded 1/8-27 NPT which will accept the sender that comes with your new gauge. The other port is threaded M12 X 1.5 which is the same thread size as the existing oil pressure warning light sender.
The adapter mounts at a right angle with proper clearances for the E-30. So - you remove the stock oil pressure warning light sender from the port, install the GMOP2 in the port and install the oil pressure warning and pressure gauge senders into the GMOP2 - wire them up (use the existing warning light wiring for that sender) and you're ready to go.
Here are some prices VDO "VISION":
350-106 Gauge - 100 psi ---------------------- $24.00
360-086 Sender - 100 psi ---------------------   26.00
240-016 Gauge Cup - Black ------------------   14.00
GMOP2 Adapter ------------------------------------    45.00
Wiring Kit ----------------------------------------------    10.00
                                                   Total    $126.00
Bill B.
95 525i auto, 5/94
ex-91 318is, 3/90 -SOLD 3/09-;)
