Author Topic: Asterian  (Read 7685 times)
Asterian
Asterian
« on: February 27, 2013, 03:07:28 PM »
Hi! My name is Roman. Currently leaving in sunny Odessa/Ukraine.
Owning E30 for more than 5 years. Almost 1 year ago M10->M42 swap was performed.
Lets start with some pics. Now my car looks like:
« Last Edit: March 10, 2014, 01:30:39 AM by Asterian »
Asterian
Re: Asterian
« Reply #1 on: March 22, 2013, 02:46:39 AM »
Some new pics from last night:
« Last Edit: March 10, 2014, 01:32:08 AM by Asterian »
Asterian
Re: Asterian
« Reply #2 on: March 22, 2013, 02:59:53 AM »
And some from past:
« Last Edit: March 10, 2014, 01:33:04 AM by Asterian »
romkasponka
Re: Asterian
« Reply #3 on: March 22, 2013, 07:09:26 AM »
Hi Asterian,
Welcome aboard!
Personally me I do not like your car design :)
In your place i would go for Alpina or M-tech 1 body kit, one color paint and some nice R15J8 wheels.
How do you like M42 engine (after M10 probably)?
E30 318is M42
E36 318is M44
Asterian
Re: Asterian
« Reply #4 on: March 22, 2013, 02:30:36 PM »
I'm also dont like current design, maybe at summer time I will put white color back.  :)
But In first priority I'm concentrated on technical side now - vibration/exhaust drone at around 2800 rpm is making me crazy and taking all pleasure from driving away.
romkasponka
Re: Asterian
« Reply #5 on: March 22, 2013, 06:15:27 PM »
Looks like valve-train job is awaiting you. At ~3000rpm chain starts to makenoise due to worn parts and if you rev it more it disappears. Often it is guides, sprockets, chain and tensioner and it is not cheap to replace all of them.
E30 318is M42
E36 318is M44
Asterian
Re: Asterian
« Reply #6 on: March 23, 2013, 10:03:48 AM »
Very sadly if all described above will be real cause, however, my engine dont making excessive noise at this rpm, just vibrating. If chain will need to be replaced, I think that instead of this job I will better buy complete engine again. Set from E36 overhere will cost around 800 Usd.
Feelings with M42 after M10 are not what I was expecting. More HP is great, but my M10 was running more smooth. Plus fuel consumption (within city) are same for both engines. This I cannt understand - how Carburetor engine can take same fuel amount that Motronic setup.
romkasponka
Re: Asterian
« Reply #7 on: March 23, 2013, 10:20:35 AM »
Even if you will buy other engine nobody will give you warranty that there will be no chain noise. It is common problem with m42. Normaly you should replace chain, sprockets, tensioner and probably some guides. All parts cost around 250-300Eu. The same price like complete engine in Lithuania. M10 is realy good engine (base for s14) with big bore and big valves. I had one long time ago. My E30 318is was consuming ~9l/100km in the town.
E30 318is M42
E36 318is M44
Asterian
Re: Asterian
« Reply #8 on: March 25, 2013, 02:48:26 AM »
For a current moment I will hope that its not chain.
First would like to try/check following:
1) In a week time I will get camshaft alignment tool to put correct camshafts position. (Now its aligned with 1-2 degree tolerance (already got engine like this));
2) Would like to install OEM type exhaust/currently I use m20 twinpipe.
P.S. More exactly - vibration/drone happening at 2500 rpm.
Asterian
Re: Asterian
« Reply #9 on: March 28, 2013, 03:00:39 AM »
My past M10:
My current M42:
Asterian
Re: Asterian
« Reply #10 on: March 28, 2013, 03:43:57 AM »
To release my crazy design ideas 2 years ago I have tried to make my car looks like "Black&White Umbrella Corp Car". Maybe OEM Alpinweiss color was better, but that period I was happy to create something new for me.
« Last Edit: March 10, 2014, 01:34:20 AM by Asterian »
keflaman
  • -Receive: 35
Re: Asterian
« Reply #11 on: March 28, 2013, 08:04:18 AM »
Hi Asterian,
Thanks for posting pictures of your car. It's always interesting to see how enthusiasts from around the world modify and maintain their vehicles.
Asterian
Re: Asterian
« Reply #12 on: April 08, 2013, 07:24:06 AM »
So finally vibration issue solved by removing non-stock exhaust bracket.
Now I'm really enjoying driving with this engine.
Ater this most interesting question for me its fuel consumption:
Highway - 7 ltr / 100 Km
City (high traffic) - 14 ltr / 100 Km
For comparison my past carburetor M10:
Highway - 8 ltr / 100 Km
City (high traffic) - 14 ltr / 100 Km (same figure)
Diff is 3.91
Asterian
Re: Asterian
« Reply #13 on: June 24, 2013, 01:54:11 PM »
After final paint job:
« Last Edit: March 10, 2014, 01:31:13 AM by Asterian »
