Author Topic: Cranks, No-start, CEL will not light up.  (Read 2202 times)
benz-tech
« on: February 24, 2013, 08:23:56 PM »
Hey all,
My '91 318i won't start. I did a stomp test immediately after I shut the car off and got 1444 (no codes). Thereafter, the CEL won't even come on. The car cranks but doesn't even try to fire. A few bits of info: mess under the intake cleaned up with all new boots, has an aftermarket chip installed. I verified 12v at pin 26 and grounds at both pin 28 and 34. Sounds like a bad ECU to me but maybe someone else has some insight.
benz-tech
« Reply #1 on: February 25, 2013, 12:41:27 AM »
small update: I don't have power at pin 54. My battery is in the trunk, where the batt would be under the hood is a block of wires on what is the would-be battery + terminal. There is no power at the top bunch of wires, but they are on the plastic body. I've serched for pictures. I will also try to download one to help explain. Do I need to have power at this terminal?
benz-tech
« Reply #2 on: February 25, 2013, 10:19:21 PM »
I will answer my question above: Yes, you should have power at that terminal. I had 0v yesterday when I but today I had 2.5v which made it much easier to trace. I dug around in the trunk and found a cobbed up fusible link with wires half soldiered to it loosely in an attempt to bridge the blown fuse. l have strip fuses from MB that I will use to permamently repair it.
colin86325
« Reply #3 on: February 26, 2013, 09:33:43 AM »
Glad you found the problem.  Make sure you use the correct amp fuse; I can't recall its rating but you can probably google "fusible link repair" and find the spec.
« Reply #4 on: February 26, 2013, 07:52:46 PM »
Glad you found the problem - IIRC it's an 80 amp.
BTW, a bad crank sensor will cause a no-start condition without setting a CEL.  If you perform the stomp test you'll get a 1444 'all is OK' code.  The crank sensor should ohm out about 640, give or take 10%.  Cam sensor should be about 1280, but won't cause a no-start.
