Author Topic: coming together finally  (Read 5336 times)
nickmpower
« Reply #15 on: January 04, 2007, 01:39:01 AM »
im just moving it with my hands on the counter weights.
nickmpower
« Reply #16 on: January 04, 2007, 09:06:12 AM »
i told my dad about 5 times not to but he insidted on carring on using the end of the crankshaft when he heped me caary it...
nickmpower
« Reply #17 on: January 04, 2007, 09:44:35 AM »
well false alarm i guess, i dunno what the deal with yeaterday was, all i know is i got up at 7:30 cause i couldnt sleep
nickmpower
« Reply #18 on: January 04, 2007, 11:14:07 AM »
haha, btw I had a nightmare that when i turned the engine over the pistons fell out the bottom of the block cause the stroke was too long, hahaha
Choking Hazard
« Reply #19 on: January 05, 2007, 09:06:04 AM »
Quote from: nickmpower;16769
Dreams are NOT subtle.  Sounds like a nightmare alright.
[SIGPIC][/SIGPIC]-Scott
nickmpower
« Reply #20 on: February 17, 2007, 12:32:33 PM »
well im back in town. hopefully i have everything i need!
nickmpower
« Reply #21 on: February 18, 2007, 12:57:03 AM »
well the slave came apart in the bellhousing, so i have to take the tranny off...
Scumball
« Reply #22 on: February 18, 2007, 08:15:15 AM »
Looking good! Will be interesting to see how it goes when you're done. I'm about to get a spare lump for rebuild, so I'm toying with the idea of giong nuts and doing something similar.
nickmpower
« Reply #23 on: March 25, 2007, 09:43:41 PM »
well im back home from college. In the past couple days i have repalced the diff cover with an m coupe unit, replaced the diff sender connector, the reverse light sender connector, and worked on finishing up in install of the seats. also installed the m20 starter, did some other wiring and put on the lower intake manifold, and some other stuff i cant remember.
Tonight i tried priming the engine but after 20 or 30 seconds of cranking the oil light did not go off. I was really scared/pissed. I hooked up a jump starter to the battery and did it again and the oil light went off withing a few seconds, so i guess it just wasnt turning fast enough to make the light go off. im releived to say the least...
still have to bolt on the seat belt buckles, put fluid in the diff, and decide what injectors im going to use then put the upper manifold on.
