Anyone who has/had a set of these ITBs,
I'm having an issue where a pretty big air/vacuum leak occurs around where the shaft that turns the throttles enters the throttle body, it looks as though there should be some sort of seal there.
Basically it leaks from where the arrow points, but from each side of each throttle. Could
Does anyone know if there is a seal you could get or if you could make one?'
Its making it hard to tune for idle, and makes the engine struggle if you blip the throttle too quick.
