My DD is a '91 4dr 5spd, probably has 1/4 mil miles on it by now. I've been collecting parts this past year to do the timing chain overhaul, possibly in the spring. Then, a few months ago, the clutch started vibrating when engaging from full stop, so I assume the clutch will need to be replaced soon. I did do the suggested "test your clutch" by going from 1st to 5th and flooring it; no slippage so maybe I have a bit of time on that one. Now, this week, I discover coffee sludge on the dipstick and oil cap. Leakdown test points to cyl 1 & 2 so, now the head needs to come off.
I need to get the car back on the road as soon as possible, so I would like to sequence these repairs, if possible. The choices are, fix the HG now & then go after the chains & clutch in spring as planned leaving the engine in situ, or pull the engine and do everything at once, even though it may take me a month to accomplish.
Thoughts? Guidance? Suggestions?
