Author Topic: S50b30 pistons, US vs EURO  (Read 8705 times)
IlovM42
« on: January 08, 2013, 02:17:21 AM »
Hi everyone.
looking to built a little N/A M42, with stock crank and S50b30 pistons (86mm bore 81mm stoke) but the problem is that here in France it's hard to find S50b30 pistons at a good price but I keep looking and i want to enlarge my possibilities
So my question is, does the US S50b30 pistons are the same as EURO S50b30 pistons? I know that there is a lot of difference between the two engine but they seem to have same bore and stroke so i guess pistons are the same?
If you have an idea of this.
Thanks in advance.
Mat
keflaman
  • -Receive: 35
« Reply #1 on: January 08, 2013, 07:29:29 AM »
Hi Mat,
In regards to your question the pistons share the same outside diameter of 86mm, however, it appears there are significant differences:
-Euro S50 -USA S50 -M42
Piston Specifications:
   -Euro S50
    Length [mm]50,6
    Cylinder Bore [mm]86
    Surface
    Bolt ? [mm]21
    Production Number85 V 105
    Compression Height [mm]31,6
    Bolt length [mm]59
    Recess Depth 1 [mm]3,72
    Valve Pocket Depth 1 [mm]3,09
    Valve Pocket Depth 2 [mm]5,86
    Standard Size [STD]
http://www.autopartoo.com/oem/bmw/11251402390.html#
-USA S50
    Length [mm]51,8
    Surface
    Bolt ? [mm]22
    Production Number86 V 134
    Compression Height [mm]32,8
    Bolt length [mm]56
    Recess Depth 1 [mm]3,5
    Valve Pocket Depth 1 [mm]0,52
    Valve Pocket Depth 2 [mm]3,11
    Standard Size [STD]
http://www.autopartoo.com/oem/bmw/11251404961.html
-USA M42
    Length [mm]51,15
    Cylinder Bore [mm]84
    Bolt ? [mm]22
    Production Number84 V 155
    Compression Height [mm]31,65
    Recess Diameter [mm]70
    Bolt length [mm]54
    Recess Depth 1 [mm]4,5
    Valve Pocket Depth 1 [mm]1,65
    Valve Pocket Depth 2 [mm]1,85
    Standard Size [STD]
http://www.autopartoo.com/oem/bmw/11251721446.html#
I don't think you have any plug-n-play options staring at you.:)
IlovM42
« Reply #2 on: January 08, 2013, 07:53:39 AM »
Waouh this is informations! thanks you Keflaman!
So US S50 pistons seems to be an option but need to be carefull with valve and head clearance, but they will give a lot more RV than EURO S50 pistons
Going to see that, but it's easier to take off some mm of a piston than adding them!
but need to see to if finfing US S50 pistons is easier/cheaper than EURO S50 pistons
« Last Edit: January 08, 2013, 07:57:57 AM by IlovM42 »
keflaman
  • -Receive: 35
« Reply #3 on: January 08, 2013, 09:19:58 AM »
If I were you I'd do a lot more searching for information rather than pistons at this point.;)
Hang around, there's bound to be some folks with a wealth of information and experience to offer you more and better advice than I can give you.
IlovM42
« Reply #4 on: January 08, 2013, 03:11:54 PM »
don't worry i don't buy/do anything for the moment, only gathering the more information I can ;)
