Author Topic: WTB: ITB's for my 91 M42  (Read 4485 times)
lateralfx
« on: December 26, 2012, 12:56:10 AM »
Like the title says looking for ITB's, dbilas is my first choice but I'm open to any complete kit or one that is comparable to it. If anyone has a set or knows where one is please let me know ASAP. Thanks guys in advance!
bme30
« Reply #1 on: December 26, 2012, 10:28:30 AM »
If you can find the bolt on kit get it.
I built my itbs with gsxr 750 itbs and that was a lot of work involved.  It runs great but still needs some more fine tuning and a redesign on the intake plenum...
5m1dy
« Reply #2 on: December 26, 2012, 07:36:04 PM »
Theres a set on german ebay that isnt dbilas
http://www.ebay.de/itm/Einzeldrosselanlage-BMW-318is-E30-M42-/350588246105?pt=DE_Autoteile&hash=item51a0b01859#ht_2074wt_1452
Obviously not a complete kit, so you would either need to build your own plenum, or go to a standalone to run alpha-n. You'd also need to sort out where the crankcase breather goes. Otherwise, the actual throttle bodies look very similar to the dbilas set i have.
lateralfx
« Reply #3 on: December 26, 2012, 11:35:16 PM »
I was and still can buy the ITB's from Extrudabody. However, it's expensive and will be over $2000 for it to have a plenum so I can turbo it. Right now my car has the AEM FIC and is set for alpha-n so I'm not using a AFM. The car run perfect and my DME has a Midnight tuning chip in it. Also my engine is a 2.1l stroker I bought from DVMotorsports with a more aggressive cam then the one MM offers in there rally engine. My car is tuned at 193rwhp but I'm hoping to see the numbers jump with a ITB setup. Thanks for the help so far but I'd like to buy something from someone here in the states and with a plenum I can run boost into.
bme30
« Reply #4 on: December 27, 2012, 01:00:38 AM »
Get the s14 itbs and plenum.  Get an adapter plate made and you should be good
lateralfx
« Reply #5 on: December 27, 2012, 01:50:35 AM »
If I lived any place else I would. Here in Hawaii we are extremely limited on fabricators and most guys charge way to much to do it locally. That's why I'm stuck looking for an already complete set. I wish our aftermarket shops could do real work instead of selling off the shelf crap.
