Author Topic: Cranking but not starting !  (Read 3412 times)
7yatna
« on: December 19, 2012, 07:52:17 PM »
hey guys ,
i need your help asap
i swaped an engine m42 from 94 e36 !
to my 90 e30 chassis !
tried to start but no good
found out that
the three relays are cut off the engine harness
i could manage the fuel pump relay
but i need your help to figure out the other 2
dme main relay and o2 sensor relay !
i need wiring and colors ! and location please !
thanks in advance !
« Reply #1 on: December 19, 2012, 08:40:56 PM »
They're located on the firewall, under a plastic cover.  You'll need to connect a positive wire off the battery block.  I've attached a clickable thumbnail below, colors are listed on that diagram.  This is a page from the electrical troubleshooting manual (ETM) - check it out.  You can download it from here.
« Last Edit: December 19, 2012, 08:43:52 PM by DesktopDave »
7yatna
« Reply #2 on: December 19, 2012, 09:11:36 PM »
thanks alot man this what am looking for !
thanks
tomorrow i`ll post what came up !
thanks again
