Author Topic: clutch  (Read 2547 times)
sha1234
clutch
« on: December 16, 2006, 12:49:38 PM »
I know its going and well i will want to replace it with something a little fancier than the saches
i want something that can clamp good and hard
and that if i turbo the car later on in its life it will be able to handle 200-250 hp
thoughts?
Jbrough
clutch
« Reply #1 on: December 16, 2006, 04:26:14 PM »
After I replaced my flywheel with a 8lb replacement and stock clutch some members were discussing that the 95 M3 aftermarket flywheels would fit.  With that you could use the bigger M3 stock clutch that is worth a heck of a lot more power and doesn't cost as much.
Some of the benefits discussed is that you get a sprung clutch instead of the solid one that comes stock on our cars.  To conteract the higher force required to operate the clutch a larger slave cylinder could be used.
Search a little bit and I'm sure you'll be able to find more info on it!
AL GReeNeRy
clutch
« Reply #2 on: December 17, 2006, 06:12:10 AM »
it might be easier to do a 325i conversion. and you get all the getrag 260 clutch discs...
p.s. hows that 40 series flow?
1991 318is : brilliantrot
genna
clutch
« Reply #3 on: March 08, 2007, 07:27:18 AM »
hi can anyone tell me where the contact point should be for the clutch mine is pretty high up on pedal
________
Marlin
« Last Edit: February 17, 2011, 12:50:49 AM by genna »
