BMW antifreeze, which is really the ONLY thing you should be using, is dark blue.
The PO may not have completely flushed the system when he started using the green stuff, so it would mix and darken the green stuff.
I wouldn't put green (or orange) stuff in, there is too much anecdotal evidence that it causes as much harm as good. More than likely the rest of the cooling system does look like that - I would seriously consider a good flush.
Probably not related to the profile gasket - that would mix oil with the coolant, you'd end up with a milky solution.
