Author Topic: Rear control arm bushings, who has 'em?  (Read 7333 times)
ScreamerBeemer
« on: December 12, 2006, 12:20:06 PM »
I've looked lots of different place for some new rear control arm bushings. I installed new offset front control arm bushings, new control arms, and the bilstien kit. Love the ride, but it feels loose in the tail end. I'm eventually going to replace the subframe bushings, trailing arm bushings, sway bar bushings and end-links, and I haven't found anyone with rear control arm bushings. I'm kicking around the idea of installing urethane, not sure if I want squeaking though.
dino245
« Reply #1 on: December 12, 2006, 12:32:48 PM »
the trailing arm bushings are the rear control arm bushings
ScreamerBeemer
« Reply #2 on: December 12, 2006, 12:40:43 PM »
Oh that makes that easy.  Potato, tater; same difference?
« Reply #3 on: December 12, 2006, 10:27:42 PM »
Ireland engineering sells urethane rear bushings--both subframe and trailing arm.
http://www.bmw2002.com/
Expect the ride quality to diminish somewhat if you decide to go this route.
Froos
« Reply #4 on: December 14, 2006, 03:49:29 AM »
I've got em (powerflex). Subframe and trailing arm, very easy to install, and not that badly priced. Haven't driven the car with it thou.
318isle
« Reply #5 on: December 25, 2006, 12:24:32 AM »
Quote from: Eurospec;15508
Have these in my car and the ride is a little harsh, but the NVH is not too bad as my car is my dd. I also have the IE springs, but looking for something a little stiffer.
Keep in mind my idea of NVH may not be the same as yours.
If a Lexus LS460 has 0 NVH and the worst is a 10, my car is around an 8 IMHO!
However, it handles like it's on rails!
kowalski
  • El\' Duder
« Reply #6 on: December 25, 2006, 03:01:33 AM »
i don't understand why everyone whines about the ride of urethane bushings. It's not like that bushing makes the whole difference in how you car goes over a bump. I have them, i have stiff springs, and all urethane bushings and my car rides great.
Sale:
Fore Sale Thread
318isle
« Reply #7 on: December 25, 2006, 12:53:55 PM »
Quote from: kowalski;16173
Ditto!
That's why Toyota makes the Lexus...to glide over pot holes and bumps and move like a ship on the ocean! :D
Bunta
« Reply #8 on: December 25, 2006, 06:52:01 PM »
From what I found researching these bushings the IE ones fit terrible.  Ive heard the powerflex or bmp ones are the only way to go.
Showing off my fresh bushings and fancy painted bits.:D
Hunter
kowalski
  • El\' Duder
« Reply #9 on: December 25, 2006, 07:13:54 PM »
the IE ones fit great when i put them in. i think your thinking about the trailing arm ones were rumored to not fit great from what i heard, but the redesigned them a while back.
Sale:
Fore Sale Thread
« Reply #10 on: December 25, 2006, 08:36:07 PM »
Quote from: Bunta;16200
Hunter
how much of a pain in the ass was it to get your sub-frame down/
Bunta
« Reply #11 on: December 27, 2006, 05:14:30 PM »
Way easier than expected.  I read so many horror stories I was totally prepared for it to suck.  The old bushings came out in one peice, I didnt have to drive the studs into the car.  I was lucky I guess.  The parking brakes were the worst part of the whole job.  Not to brag but the underside of my car is in excellent shape, no rust at all hardly any corrosion on anything and its always been a Mid Adlantic car(usually rusty).
Id think it was worth it to do those bushings mainly because I could paint and clean everything really well(my bushings were not worn hardly at all even at 120k).  Get it done and over with and not have to worry about it.
Its easiest with 3 people too. One running the jack and one person on each side to pry and pull down on the subframe and arms.
Have Fun
Hunter
« Last Edit: December 27, 2006, 05:16:39 PM by Bunta »
nickmpower
« Reply #12 on: December 27, 2006, 09:04:57 PM »
In my experience both the old and new IE bushings fit like shit, along with all of IE's products. I thought i messed up my subframe when installed the camber correction but the akgs fit oh so good
Fife318is
« Reply #13 on: December 27, 2006, 10:28:00 PM »
I disagree. I think that Urethane bushings are overkill for most cars that see primarily street duty. Just new stock bushings should provide worlds of improvement over the 15 year old worn out units in there now.
« Reply #14 on: December 28, 2006, 02:19:05 AM »
Quote from: Fife318is;16325
yup i feel the same way, i already have stock subframe bushings waiting for install.
I am however changing the trailing arm bushings to polyurethane...
