Author Topic: engine code  (Read 3178 times)
RED IS 91
engine code
« on: December 07, 2006, 04:01:38 PM »
I did the stomp today and the code came back 1262 IDLE SPEED ACTUATOR.
Is this the same as idle speed control valve ??
e9nine
engine code
« Reply #1 on: December 07, 2006, 05:19:53 PM »
Same as ICV
FL318is
Dang it!
« Reply #2 on: December 08, 2006, 12:53:39 PM »
Where is the original thread that tells you how many stomps and codes?
RED IS 91
engine code
« Reply #3 on: December 08, 2006, 01:34:24 PM »
« Last Edit: December 08, 2006, 01:41:36 PM by RED IS 91 »
FL318is
whew
« Reply #4 on: December 08, 2006, 01:59:53 PM »
thx. i owe you one!
gunsmoke
i got curious...
« Reply #5 on: December 09, 2006, 03:13:24 AM »
so i read this thread and got curious, so i tried the stomp test on my car. first off, my car is running perfectly.  it's actually never run better, but i got a fault code. 1241, which is 'Air Mass Sensor', then says
      "Note 1) Code 41, 1241 and 2241 can be false Air Mass Flow Meter codes on 1992 and later models. The actual cause of the code is a faulty Idle Air Valve and the need for an updated EPROM. See all applicable service bulletines  for
further information."
any idea what that means if my car is running well?
e9nine
engine code
« Reply #6 on: December 09, 2006, 08:16:13 AM »
Quote from: gunsmoke;15295
"If it aint broke - don't try to fix it" :D
RED IS 91
engine code
« Reply #7 on: December 09, 2006, 08:34:05 AM »
It's says 1992 and later cars .................
