Hey folks,
I decided to write a new thread because I was unable to find what I was looking for on the other threads in this forum.
As the title suggests, my car is idling high and she won't come down, here are some facts to help weed things out.
I have just recently completed "the mess under the intake" after one of my heater coolant lines burst, I have replaced almost every coolant hose, everything has been put back together, as of right now, there isn't any air left in the coolant lines as I have bled it all out.
The Problem:
When the engine starts cold (starts fine, no problems) it idles a little low but then levels off and starts idling at the correct RPM's, a little below 1K, after a few minutes when the engine starts to heat up, the RPM's steadly rise and then stay around 1200RPM's and 1500RPM's I have no idea why it's idling so high.
I have checked all vacuum hoses for a possible leak, everything is secure, I have rechecked my ICV, looks good, the idle isn't fluctuating, it is just steady at a high RPM, NOTE: I did change the position of the ICV slightly.
I don't really have any ideas other than a vacuum leak which I have checked and re-checked for, everything seems to be hooked up correctly and she starts right up then starts idling high.
Any advice on this would be very much appreciated as this is my DD, and would like to get her back on the road this weekend.
Thanks so much for your help in advance!
Cheers!
Sophia from Seattle
