Author Topic: Possible clutch replacement in my future...  (Read 2534 times)
m42 fan
« on: December 03, 2006, 04:37:02 PM »
Gentlemen,
                 Yesterday I installed my H&R OE/Bilstein HD setup (Looks and works great btw!).  On my test drive, I noticed, for the first time, my clutch slipping. :mad: So, if I'm going to have to drop the Exhaust, Driveshaft, and Tranny, I want to make sure it only has to happen once.  With that in mind, I'd like some suggestions as to what else I should be taking care of while I have the car apart.  Thanks!
Brian
johna
    • My BMW 3 Series Website
« Reply #1 on: December 03, 2006, 05:26:45 PM »
Rear main oil seal, guibo.... and maybe a lighter flywheel and short shifter.
m42 fan
« Reply #2 on: December 03, 2006, 05:54:00 PM »
Shifter:  already in...
Guibo:    Standing by...
Rear main seal:  Good call, I'll have to pick one up...
Flywheel: Good idea, but it's not in my plans for the car.  Either too expensive or a PITA, depending on which route you try and go.
Thanks for the ideas, keep 'em coming!
Brian
Febi Guibo
  • m42 reporter
« Reply #3 on: December 04, 2006, 08:02:36 PM »
center support bearing; new guibo bolts; check the slave cylinder; rear shifter rod bushing thing; new o2 sensor... what else is down there?
give everything a good cleaning too...
Support M42club.com !!
