Author Topic: Gas pedal went out???  (Read 2628 times)
m42hellrot
« on: August 30, 2012, 09:57:16 AM »
on the way home from school going a across the bridge i pulled over too take a picture and it was a bumpy/pot hole kinda road then my pedal went out. when i pushed it down it felt like there was nothing there. could that be a throttle cable im confused on this one and im missing school because of it HELP!!!!!
THANKS
CHRIS
wazzu70
  • Nasty Nick
  • -Receive: 18
« Reply #1 on: August 30, 2012, 12:53:31 PM »
Open the hood and see if the cable is attached to the throttle.
The gas pedal on these cars are known to break as well. Make sure the top of your throttle pedal is still attached.
-Nick
91 E30 M42 with VEMS
« Reply #2 on: August 30, 2012, 05:33:23 PM »
Sounds like the little crimped stopped on the end of the cable came off. That happened to me once. Assuming all the other stuff didn't disappear, you might be able to crimp a butt-splice onto the end until you can order a new cable.
You should also see about setting the gas pedal stop properly. The little end crimp breaks off when it is set incorrectly. Push the pedal all the way down and then adjust both the pedal stop and the threaded adjuster on the TB so that the throttle is like 98% open. If the throttle is 100% open before the pedal is down, you will break the end crimp off when you floor it.
keflaman
  • -Receive: 35
« Reply #3 on: August 31, 2012, 03:49:30 PM »
So...what'd you find?
downforce22
  • How many e30's is too many??
    • Drive4Corners
Re: Gas pedal went out???
« Reply #4 on: April 15, 2016, 03:22:04 PM »
The crimped piece on my throttle cable broke off as well. I ordered a new cable. Looking for other people who have replaced this cable, seems like an easy enough job.
'91 318is | '91 325iX | '86 325iX | '86 325i S38
www.drive4corners.com
