hey everyone. im brandon. i have a 91 318i sedan. just checking out this site to see if there are any real people and not assholes like the majority of bf's.
with that said, im having a problem with my bim bim.
i was driving my car home from my old job and decided to stop by my new job. so, i go in to my new job and come out about 10 minutes later. i put the key in and everything works like normal with the exception of not being able to hear the fuel pump prime. i didnt really think much of it so i went to twist the key to crank her. nothing happened. radio and lights still work but ,absolutely nothing happens when you turn the key to "start" no cranking, no fuel. seeing is how everything else worked, thats why i checked the ignition switch. figured maybe it lost a contact on the inside or something( stranger things have happened).
ignition switch works fine, none of the fuses are blown and none of the relays are torched.
the only thing that makes any sense to me right now is that right before i pulled into the parking lot, my speakers started acting wierd. kind of like dimming out and coming back to normal. does the speaker harness run near any of the wiring for the fuel system, battery, anything having to do with the functional running fo the car?
lets see if anyone can help me solve this one.
