Seafoam
Author Topic: Seafoam  (Read 9849 times)
thumper3ld
  • fathead ***
Seafoam
« Reply #15 on: March 22, 2006, 08:59:04 PM »
Quote from: dude8383
clear your pm box dood tryin to send chu a PM
Box cleared
Seafoam
« Reply #16 on: March 23, 2006, 12:42:01 AM »
Quote from: thumper3ld
Box cleared
you can have 500 PM's in your box. do you PM that much?!?!
thumper3ld
  • fathead ***
Seafoam
« Reply #17 on: March 23, 2006, 07:06:26 AM »
Quote from: asubimmer
500?? I think you added a 0 somewhere there cuz I can only have 50
Febi Guibo
  • m42 reporter
Seafoam
« Reply #18 on: March 23, 2006, 07:31:29 AM »
thump used too many of his peak and roaming PMs...
I've got him on the M42 'friends and family' plan now.... it's only $19.95 a month, before tax.
Support M42club.com !!
Seafoam
« Reply #19 on: March 23, 2006, 07:49:53 AM »
hehe the roaming charges will getcha
Seafoam
« Reply #20 on: March 23, 2006, 11:58:17 AM »
Quote from: Febi Guibo
haha man im still stuck with that shitty commission...:D
Seafoam
« Reply #21 on: March 24, 2006, 11:40:18 AM »
Cool thanks. I'll give it a try. However, I heard something to the sort that with older engines, puttings stuff like this into ur crankcase can be bad cause over the years, some of that build up may actually help seal in leaks. There were some horror stories of people doing things similar to this and ended up with new leaks. What do you guys think?
Heh, a buddy of mine had that exact problem with SeaFoam in his 1987 Toyota pickup.  It has 250000 miles on it, and when he Seafoamed if cleaned all the gunk out...the gunk that was sealing his head gasket in a number of places.  Coolant-oil slurry is gross, lemme say that!  I would not worry about that happening though.  If your motor is in that bad of shape already then you probably need to do a LOT of work on it anyway.
thumper3ld
  • fathead ***
Seafoam
« Reply #22 on: March 24, 2006, 09:12:14 PM »
Quote from: bmwman91
LOL, As true as that may be, the gunk maybe saving me from doing the work on it right now.
Seafoam
« Reply #23 on: March 25, 2006, 10:48:52 AM »
Hehe.  Yeah, I do not think there should be too much crap built up in anyone's engine.  I think the M42 is a lot more sensitive to oil leaks & stuff...and I do not think many of us here would run around in a car that burned oil & let it be.  Hell, the carbon buildup raises our CR anyway wheeee!
