Author Topic: A/C compressor wont engage  (Read 6551 times)
Bimmer805
« on: August 19, 2012, 09:37:30 PM »
so about a year ago i cut my a/c belt becuase it wasnt blowing cold and i didnt need it well recently i installed a new belt because i want to recharge my system and i want my a/c back. well turns out when i press the a/c button the aux comes on but the a/c compressor wont engage at all. how do i fix this problem please help:(
« Reply #1 on: August 20, 2012, 06:53:59 AM »
Might be that the clutch is shot, or that the pressure switch isn't working.  I've never done any A/C work on the e30 so I'm not sure which one to short, but the pressure switch is up near the passenger headlight on the receiver/dryer.
Bimmer805
« Reply #2 on: August 20, 2012, 10:31:59 AM »
Oh ok I check for power there and I didn't get anything
Bimmer805
« Reply #3 on: August 20, 2012, 04:39:03 PM »
i have check for power on the pressure switch and im getting no readings
« Reply #4 on: August 20, 2012, 07:41:44 PM »
Did you download the e30 electrical troubleshooting guide yet?  Definitely get that - it explains all this stuff.  I grabbed the '92 318ic version as the '91 318 has some missing pages:
http://wedophones.com/BMWManualsLead.htm
Lemme see if I can post it somewhere, it's only about 10MB zipped.  Or PM me an email address and we'll see if it'll go.
« Last Edit: August 20, 2012, 07:57:46 PM by DesktopDave »
« Reply #5 on: August 20, 2012, 07:55:46 PM »
Looks like fuse 20 feeds the A/C switch with a white wire, which powers up the 'evaporator temp regulator' unit, runs the aux fan on low, and lets Motronic know that it should bump up the idle with a black/violet wire.
You might be able to test this by seeing if the A/C switch turns on the aux fan in front of the radiator.   Should happen with the ignition switch in position I or II.
Once the HVAC unit is running, looks like it uses two controls.  There's that pressure switch (may be two switches on earlier models) and a evaporator temp regulator (not sure what that is though).  Those send a signal to the 'compressor control unit' over a black/red wire.  That control unit then finally switches power from a green/black wire to a black wire that powers the compressor clutch.
Bimmer805
« Reply #6 on: August 20, 2012, 10:27:48 PM »
I push the snowflake button and the aux fan does come on
DanOKC
« Reply #7 on: August 20, 2012, 10:56:40 PM »
If the system has lost most of the freon, the pressure switch will keep the compressor from coming on.  Try to jump across the pressure switch terminals with a short jumper wire to see if the compressor clutch engages. The pressure switch will cut off for too low pressure or too high.
I had to jumper mine to start charging it last year. Once you have a minimal charge, you can remove the jumper, & reconnect the terminals to the pressure switch.
Best bet would be to evacuate the system with a vacuum pump, make sure it holds, then recharge.
Bimmer805
« Reply #8 on: August 21, 2012, 01:43:24 AM »
how do i go about jumping the terminals?
« Reply #9 on: August 21, 2012, 05:59:48 PM »
Pull the connector off the switch & put a short bit of wire into the wiring harness connector.  I don't think that carries much current, so a paperclip bent into a u shape might work well too...but be sure you don't test any ignition components that way...
DanOKC
« Reply #10 on: August 21, 2012, 06:43:14 PM »
Follow the wires off the switch about 10 inches away from the switch, there is a connector there that you unplug, squeeze the tabs & pull the connectors apart. Put the paper clip or wire in there. Do this for just a few secs to see if compressor kicks in.
Bimmer805
« Reply #11 on: August 22, 2012, 04:58:50 PM »
theres one like a three prong and theres one with a two prong which is it?
DanOKC
« Reply #12 on: August 22, 2012, 06:34:57 PM »
2 prong, and when you unplug it, the you'll see 2 female contacts on harness side, and 2 male on the switch side. You jumper the 2 female contacts.
Bimmer805
« Reply #13 on: August 23, 2012, 02:09:08 AM »
ok ill try that.
Bimmer805
« Reply #14 on: August 24, 2012, 02:30:32 AM »
yipee it worked lol. so what do i do next for recharging?
