Author Topic: Interest in Bolt on Turbo kit?  (Read 36238 times)
ShoutOut
Re: Interest in Bolt on Turbo kit?
« Reply #45 on: April 10, 2013, 05:36:05 PM »
Jake this looks awesome.
I track my 318is at Summit Point, NJMP, and VIR. The car is great but lacks power, duh. I'm VERY interested in this kit. My main concern is reliability. I've read where some forced induction system have problems running lean.  AutoX is one thing but a 30 minute session of taching out the gears is another. The M42 lacks power but it makes it up in reliability. It will stay at redline all day at the track and then drive you 4 hours home.
This is my car at VIR. Coming out of Oak Tree I lost all my momentum which is very frustrating >:(. https://vimeo.com/63205881
If you think your kit and tune will hold up, I'm in.
jakeb
« Reply #46 on: June 29, 2013, 07:05:58 AM »
I always forget I have this thread here too....  Either way kits are in production.  Two more about ready to go out.  Here are some pictures...
Intercooler brackets pre powder coat. (one extra here...)
Manifolds all tacked together
Box full of hardware...silicone couplers, injectors, bpv, etc etc
Aluminum IC pipes in progress
[imghttps://lh5.googleusercontent.com/-9jdwT8HJvUU/UczaqQbnmYI/AAAAAAAAHJI/5auGCC4etk8/s640/IMAGE_133.jpeg]http://www.m42club.com/img]
Everyone likes pictures so here are some more....IC pipes all coated with couples, etc
COP kit...
http://www.classicdaily.net - swapping this into that
http://www.blunttech.com - all your parts needs
The Collector
« Reply #47 on: June 29, 2013, 10:41:49 AM »
How much are these kits
Eyecmonsters
« Reply #48 on: July 16, 2013, 04:38:01 PM »
I want one! Now. Contact me! I made this account just so I could get intouch with you!
BimmerJones
« Reply #49 on: August 22, 2013, 02:21:32 PM »
Hey guys, I have purchased this kit and the car is up and running!  I have to say first that JakeB is an awesome guy to work with, he has helped me every step of the way, with installation and trouble shooting little miscellaneous issues.  Now to the kit, quality of all the pieces is fantastic, all the welds look great on the manifold and downpipe.  I had some issues from user error installing the injectors and when I let Jake know what was going on he sent me a new set just in case.  First impressions with driving the car... It is amazing.  The power is just incredible especially after 4,000 rpms, so much torque!  It really throws you back in your seat and it has made me fall in love with my e30 all over again.  I can't wait to install a fresh head gasket with arp studs and crank up the boost!  It the form it's in now, I bolted this kit on to a stock 165k mile motor and it seems to be loving it.  I'm walking stock e46 m3's and driving the car is just an absolute blast.  I was originally going to buy another e30 to drive daily but this car is so much fun I couldn't imagine not driving it everyday.  I can't stress enough how great of a seller Jake has been to work with and he hasn't shrunk or disappeared at any issue and is continuing to help me out on a daily basis.  Anyone on the fence thinking about it, I'm telling you from experience, just go for it.  I'll post pictures asap and continue to let you guys know what is happening but it is by far and above the most fun car I have every driven and the power finally matches the handling characteristics of this lovely machine BMW made.
The Collector
« Reply #50 on: August 22, 2013, 02:38:19 PM »
How hard and how much did it cost you. All together.
The Collector
« Reply #51 on: August 22, 2013, 02:43:12 PM »
My 318is is wanting this so much!
BimmerJones
« Reply #52 on: August 22, 2013, 03:07:05 PM »
Not hard, just time consuming.  The exhaust manifold is tough to get on and off, because of the way the engine is tilted.  Everything else is pretty simple.  I deleted my a/c because it wasn't working that well anyway and I figured the weight savings would equal out what everything else would add.  You need to have a dremel or a way to trim some things.  Some basic experience is all I had, the most complicated job I've done is a cooling system overhaul.  So if I can do it on jack stands in my buddies garage you can do it.  I think the total cost with all the trips to the auto store, the wideband and boost gauge, aluminum intercooler piping powdercoated black, cermaic coated exhaust manifold, turbo and downpipe came out to right about $2,300.  The base kit is $1,700 and with my extras it was about $1,900.
The Collector
« Reply #53 on: August 22, 2013, 04:41:36 PM »
I am redoing the motor in mine. After 300thousand the rings were a leaky. On cylinder 4. So I wanna do the turbo swap. I'd like to see pictures if you can.:)
partner103
« Reply #54 on: August 19, 2014, 04:56:46 PM »
I will definitely be in touch on this.... question is, M42 with 250 kms... does it worth turbocharging?
Tgoode318
  • -Receive: 11
« Reply #55 on: August 20, 2014, 10:37:28 AM »
You should do a compression & leak down test on the engine to answer that question. You can probably get away with this kit as its very low boost if your numbers are good. But with that many miles on the engine it will only be a matter of time before you have to rebuild, so be ready and make sure your $$ is right! People often times put all their money in the turbo setup only to have the engine blow later.
Btw i have contacted jakeb once a couple of months ago and he never answered me back.
-'94/05 M42 Convertible
-2001 330CI M Package
-2016 M4 Competition
wazzu70
  • Nasty Nick
  • -Receive: 18
« Reply #56 on: August 20, 2014, 11:31:35 AM »
Great advice. A leakdown test is simple and will answer your questions pretty thoroughly :)
-Nick
91 E30 M42 with VEMS
Nick_318is
  • -Receive: 11
« Reply #57 on: August 21, 2014, 10:27:36 AM »
From what I hear he is very responsive, maybe not from a PM, try e-mailing jake at classicdaily.net
namzat18
« Reply #58 on: August 21, 2014, 01:43:04 PM »
Id buy in a heart beat
lahondal@hotmail.es
« Reply #59 on: August 28, 2014, 10:12:11 AM »
Me too, if were available for E36...
