Author Topic: AFM door sticking open, choking engine  (Read 2445 times)
M42_Jester
« on: August 11, 2012, 01:36:22 AM »
Has anybody else had this problem? It mostly happens when I accelerate, the door will stay open and I will have no power and the engine shudders. How do I fix this without forking out a couple hundred dollars for a new AFM?
Cheers,
Jester
bmwconnect
« Reply #1 on: August 11, 2012, 06:13:31 AM »
Sounds like the spring has broken in the housing. You should be able to get a used unit for fairly cheap off the forums here or at a junk yard
Midnight YouTube Channel
RED IS 91
« Reply #2 on: August 11, 2012, 12:04:43 PM »
buy my afm in the for sale section?
M42_Jester
« Reply #3 on: August 11, 2012, 08:18:52 PM »
Quote from: bmwconnect;114509
I should clarify, the door doesn't stay open forever. It just doesn't close straight away. I've had the problem before, and a hit of WD-40 did the trick then. I just don't want to keep putting that in an area that sucks in air to the engine
