anyone want to swap?
i can see S70 block with 2 S52 heads with twin vanos for each one 48 valves 12 ITB's lot of carbon and everything else twise!
Model BMW S70/2
Type 6.1 liter, 48 valve V-12 with aluminum block and heads, 627 bhp
Bore and stroke 3.38 x 3.41 in (86 x 87 mm)
Displacement 370 cubic in, 6064 cc
Compression ratio 10.5:1
Engine control system Bosch Motronic with port fuel injection
Emissions controls 3-way catalytic converter feedback fuel-air-ratio control auxiliary air pump
Valve gear Chain-driven double overhead cams, 4 valves per cylinder, hydraulic lifters, variable intake timing
Power (SAE net) 618 bhp @ 7400 rpm
Torque (SAE net) 479 ft-lb @ 4000 rpm
Redline 7500 rpm
The McLaren F1 with the BMW S70 engine had a 0-60 mph time of 3.1 seconds and a top speed of 230-240 mph. The McLaren set the world speed record of 240.1 mph for the fastest production car in March 1998.
The engine for the McLaren F1 LM model produced 680 hp and 520 ft-lbs of torque! Issued in honor of the McLaren F1's that won the 1995 LeMans race, the LM's set a 0-100-0 mph world record for a production car by ripping through the tach in a gut wrenching 11.5 seconds while traveling a distance of only 828.4 feet!
