Author Topic: Trying to remove ignition key lock assembly.  (Read 3281 times)
gusgriff
« on: July 30, 2012, 04:46:23 PM »
The key does not work in the ignition but works in all other locks.  The key will not turn the tumbler assembly.  I tried to disassemble but the key must turn the lock to remove the tumbler assembly.
Need Suggestions.
deansweet
  • -Receive: 12
« Reply #1 on: July 31, 2012, 02:53:43 PM »
Has the key ever worked in ignition?
call BMW and see if they can get your key code and possibly a replacement for you? If it's like our 318is the door lock cyls had been rebuilt and we needed two separate keys(1 for ignition and trunk, 1 for both doors).
