There are valve reliefs on the piston from factory, this is all i can see in your photo. This is correct and required to clear the piston. You can compare the piston in the next bore to see if the piston has any damage.
I dont see any evidence of valve to piston contact. Looks ok to me.
The valve lift is arround 9,5mm iirc
