Author Topic: power antenna help  (Read 3473 times)
76m2002
power antenna help
« on: July 21, 2012, 02:02:01 PM »
I'd like to replace the antenna mast from a very gummed-up power antenna on our '91 318is.  However, the nut at the base of the mast (yellow arrow in pic) is stuck.  It will rotate, but will not come out.  The housing has a lot of white salty precipitate, so I've been soaking the assembly in CLR, which has removed most of the residue, but has not freed up the nut.  The replacement mast includes this nut, which is attached to a barrel with male threads.  I cannot figure out why the nut can turn, but will not back out of the antenna housing.
Any hints or suggestions before I resort to the cut-off wheel?
carlos318is
power antenna help
« Reply #1 on: July 22, 2012, 02:45:14 PM »
Just cut it off mate other wise you will be there forever
