How much do you have invested in the setup ??
any rubbing issues yet ??
I need to do my suspension and was thinking of blistein touring shocks and struts but not lowering .
I have to do some research and see what the cost difference is.
Unless someone has already done that and would like to share notes
Oh Yea, Your car looks good :cool:
I have heard both sides of the spring/strut issue. From what I gather there are pros & cons. In my case most of the roads here are "flat" so the oil pan issue is not as critical as some of the roads I have read about on this forum. As far as rub, not at all. I will be going to 16x7 later and do not see a rub issue even with bigger tires.
With the H&R sports and the Bilstein sports I def got a lowering so if you do not want a lower stance, I would not recommend them. I find the ride to very comfortable and not at all rough.
Thanks for the compliment. I feel like my car has a long way to go and may return to the 4 headlight config and re-route the CAI later.
I spent about 600 on springs and shocks.
