Author Topic: Nut fell into motor. (PICS!!!)  (Read 5608 times)
thebutcher37
« on: June 30, 2012, 03:52:02 PM »
I finally had time to check and decided to remove the head on my motor that previously seized up on me.
I only found one nut laying on my piston head.. what gives? :eek:
So can anyone help me find out why Im missing three other nuts from my motor?
LOL...
How bad does this look?
I cranked the motor by hand after removing the nut, and it goes around smoothly.
Wonder how this happened?
I had some work done, the crackpot who put the head back on dropped the nut into the chamber somehow, or maybe through the spark-plug hole. Thats my only guess???
Looks like one of the nuts used to hold down the camshaft.
Since then I picked up another m42 and its in my car now running fine...  but I'd like to put this one back in my car because it was not leaking, and was in overall good shape, timing components, water pump t-stat....
What shall I do?
jou ma se poes in \'n fishpaste jar.
Geoff
« Reply #1 on: July 01, 2012, 08:02:42 AM »
actually,  altho it looks ugly,  none of that damage looks like an engine killer.  I would tend to think that, after being reassembled, it would be a good back-up motor.   With a new head gasket,  and assuming it passes a compression test,  it will be fine.   Altho,  you may need to stay far away from the guy who dropped em in there..
                                                         Geoff
« Reply #2 on: July 01, 2012, 08:30:35 AM »
I agree, run it regardless.  I might give that dinged valve an overnight leakage test first...but your nut-stamper is quite the testament to BMW's metallurgy, isn't it?:D
visionracingdevelopments
« Reply #3 on: July 01, 2012, 11:55:29 AM »
Recon you were very lucky it didn't catch the corner of the valves and mash up them up.
http://www.visionracingdevelopments.co.uk
For sale:
COP converion kits
M42 Silicone coolant hose kits
Braided brake line kits
Performance clutches
Performance brakes
PM me
romkasponka
« Reply #4 on: July 01, 2012, 04:52:51 PM »
con rods possibly are bent, so better check them...
E30 318is M42
E36 318is M44
keflaman
  • -Receive: 35
« Reply #5 on: July 02, 2012, 06:59:25 AM »
Quote from: romkasponka;113512
He did say the motor seized up, so it would (will?) be interesting to find out the extent of damage.
Geoff
« Reply #6 on: July 02, 2012, 09:37:48 AM »
I'm guessing how many revs it was turning when it seized,
           "may have some bearing on it"
                                      drum-kick
                           i'll be here all week
                                  try the veal
                                          :rolleyes:
                                                Geoff
thebutcher37
« Reply #7 on: July 03, 2012, 02:35:30 AM »
Quote from: Geoff;113494
                                                         Geoff
Thats what I was saying.
Quote from: DesktopDave;113497
Seriously... I like me my M42 more year after year.
Quote from: visionracingdevelopments;113506
Yes, my thoughts exactly.
Sure hope not, but I have high hopes for the better.
Quote from: keflaman;113522
[Fingers Crossed]
Quote from: Geoff;113527
                                      drum-kick
                                  try the veal
                                          :rolleyes:
                                                Geoff
LOL, Well I should have mentioned the car was driven back n forth for about 3 days, and felt fine before the incident. But, THE GOOD NEWS about it seizing up is that it happened upon starting the car/the car not starting one day. On this day I drove a couple miles to my parents, parked the car for a few minutes than when I was about to take off, I started the car but it barely turned over and then would not start. after pushing it into the driveway I later noticed the motor was seized. Fast forward, motor was replaced and sat in garage til this month.
Geoff
« Reply #8 on: July 03, 2012, 06:31:27 AM »
the fact that it was barely turning at all when it locked up bodes well, for the bottom end, I think.   I'd give it a chance to live again.
        Geoff
thebutcher37
« Reply #9 on: July 07, 2012, 03:14:41 PM »
Quote from: Geoff;113544
        Geoff
Definitely!!!
It took me this long to take a look at it, imagine how long it'll take me to get it back in a car!
Come back for thread updates in say.... 1 year. :rolleyes:
