Author Topic: m42 supercharger  (Read 18884 times)
fast2002
m42 supercharger
« on: June 21, 2012, 10:38:47 AM »
Where can I find a supercharger new or used?  bbsports@msn.com
LeeThompson
m42 supercharger
« Reply #1 on: June 24, 2012, 12:38:44 PM »
Downing Atlanta makes the only bolt on supercharger for our cars. They use the Eaton M45 if I am not mistaken. So if you are creative, you can make your own. I would not pay more than 800 bucks for a used one, However on ebay, I just saw one go for 1800 bucks with well over 150K miles. Honestly, I would put a s52 in the car. More power for the money.
axisofjustice
m42 supercharger
« Reply #2 on: June 26, 2012, 05:49:44 PM »
God luck finding anything close to a full kit for $800, and for those who want to keep the balance of the 4 cylinder weight, there's nothing wrong with keeping your m42.
DASC kits used the Eaton m62 similar to the merc c230 unit.
My DASC M44 e36 kit on my M42 e30 project car:
« Last Edit: June 26, 2012, 05:52:45 PM by axisofjustice »
ReSuL
m42 supercharger
« Reply #3 on: July 17, 2012, 07:46:47 AM »
is it the idle control valfe on the top?? if so where does the hoes go that curves to the left side??
doitover
m42 supercharger
« Reply #4 on: July 17, 2012, 09:28:22 AM »
It doesn't look like his is connected yet. On the original kit, it plugs in where the original ICV connected. If you emliminate the mess under the intake, I believe it plugs into a connector on the boot between the throttle body and the AFM.
Quote from: ReSuL;113764
ReSuL
m42 supercharger
« Reply #5 on: July 17, 2012, 10:56:39 AM »
Quote from: doitover;113766
thank you for the reply.. I will be doing the same job next week actually.. I had a eaton m90 thunderbird cs kit..
I have two questions: 1) where does the pipe that goes into bypass walve comes from?? I mean where will I I take the boost for bypass??
2) It is possible to put a boost gauge on a SC system?? If possible where and how??
thank you for your anwsers..
axisofjustice
m42 supercharger
« Reply #6 on: July 17, 2012, 04:32:42 PM »
There are boost/vac ports on my intake, icv goes to intake boot. Boost gauge is easy, tee in anywhere after the point where s/c pressurizes air.
doitover
m42 supercharger
« Reply #7 on: July 17, 2012, 08:13:31 PM »
I'm probably misunderstanding your question but the ICV outlets before the SC but the bypass would be open while idling. Under the ICV is the bypass path. The bypass is external on the SC Downing Atlanta did.  I think some newer units have it in the SC housing.
Quote from: ReSuL;113768
ReSuL
m42 supercharger
« Reply #8 on: July 18, 2012, 01:14:05 AM »
here is what I am wondering.. I put ared arrow on the pipe and I am wondering where it goes...
and here is the SC kit I will install..
doitover
m42 supercharger
« Reply #9 on: July 18, 2012, 10:24:16 AM »
That looks to me like a vacuum line that is used to control the bypass.
It can tap into any other vacuum line. I'll try to get a picture of where
mine goes later today.
Quote from: ReSuL;113788
ReSuL
m42 supercharger
« Reply #10 on: July 18, 2012, 02:49:51 PM »
Quote from: doitover;113797
I would really appriciate it.. that is wxactly a vacuum line to vontrol bypass and ı need to know where it comes from...
ReSuL
m42 supercharger
« Reply #11 on: July 19, 2012, 09:00:57 AM »
actually I saw a photo on the net that show the pipe  I showed goes somewhere just after the throttle body.. but I believe it should go somewhere in the intake manifold.. I am really confused....
doitover
m42 supercharger
« Reply #12 on: July 19, 2012, 09:32:17 AM »
I didn't get a chance to take a picture yesterday but I did have a look. It does go to a port on the throttle body. That is correct as you want it before the supercharger.
Quote from: ReSuL;113820
ReSuL
m42 supercharger
« Reply #13 on: July 19, 2012, 02:46:54 PM »
Quote from: doitover;113822
here is another mystery :D what do you mean by It goes to a port on the throttle body
ı saw it goes somewhere between throttle and supercharger.. never saw somewhere on the throttle body.. Luckly I still have time to do it.. tomorrow I am starting to make the flanges for supercharger.. but not more than one or two days.. If you have a chance to tka a picture during this time I would really appriciate it..
by the way if you have a boost gague I also kindly want its connection photos.. :D
thank you for your help..
ReSuL
m42 supercharger
« Reply #14 on: July 19, 2012, 03:43:27 PM »
here is the picture I saw its connection.. only question is that if it is true or not??
