Author Topic: 1991 BMW 318i sedan 5spd  (Read 3183 times)
ecuastyle84
« on: June 21, 2012, 10:12:28 AM »
This started as a restoration project but I ended up buying a cleaner e30 to start with, so I have no need for this one anymore. The body is solid with a few minor dings/dents/scratches. Paint is in good shape, with a good wet sand and buff this car will definitely shine. 5spd sedan, it has 230k miles with 142k miles on the motor, new spark plugs, new coolant temp sensor, new temp gauge sensor, new oil pressure sensor, new oil pan gasket, new tstat, new water pump, and new rad hoses. The car runs and drives strong minus a slight sputtering after driving around for about 10mins which just could be a afm based on the codes it was showing when i did a stomp check. A muffler will need to be installed but i have a used one in good condition. Interior is pretty clean minus two 3in cracks on the dashboard by the passenger side and a torn driver seat. The rear driver side door doesn't open and the window switch doesn't work for it either. Hood doesn't close due to the spring breaking apart which is a easy fix, just haven't had the time to fix it because I'm too busy working on my current e30. This would be a great restoration project or candidate for a swap. Asking $2,000 obo
If you would like additional info or would like to come check it out let me know. Availability is mon-fri after 6pm and sat-sun anytime.
Thank you
« Last Edit: June 27, 2012, 10:22:04 AM by ecuastyle84 »
« Reply #1 on: June 21, 2012, 04:09:23 PM »
Approved your post, not sure why it was blocked.
Good luck with your sale...
ecuastyle84
« Reply #2 on: June 27, 2012, 10:23:12 AM »
Bump...need to get rid of this quick
ecuastyle84
« Reply #3 on: July 11, 2012, 10:08:35 AM »
sold
