I've acquired a car equipped with a DASC setup. With a Vortech SFMU that is said to be not setup and possibly not working... It is installed, but I have not verified that it was done properly. As of now the BPV is ziptied to recirculate. The car runs and drives fine during cruising pace and modest acceleration, but if I give it a little bit of push in 2nd it starts to buck. It feels like a very hard hesitiation/stumble/stutter and will not stop until I let off. I have been gentle and only allowed this to happen two brief times. The car runs pretty good otherwise.
As may be visible in this picture, it appears to be using yellow injectors and an e36 rail/fpr, and from the look of the TB elbow bend I am assuming this is an M44 DASC (not 100%).
I am very new to e30s, the M42, and also tuning older fuel injected and S/C cars. I have had older cars (carbed), and newer cars (obdII) most have been domestic. I have owned a few turbo cars and an S/C car, but all were factory stock affairs.
Can anyone experienced or who runs this type of kit advise me on the best solution to get this setup sorted quickly and cheaply? I'd like to get started rebuilding this car (it is nearly in peices) but not until it is running well and boost is in effect.
I have toyed with a few ideas:
Try to see if this SMFU works and is properly installed, then tune with it.
Get a new RRFPR and tune with that.
Get some sort of ECU setup (MS/II, TunerPro?, Etc???)
These options, as you know, are all potentially viable, but as said, I want to get the car running well for low cost so I can build it, take what I need from my other car, then sell the other car and use that income to make this one that much better.
So, essentially I am kind of asking for a handout of free advice. I assure you I have read as much as I could understand on threads and projects others have done. I comprehend the basics for the most part. I do not know the details of how to tune this setup though.
I assume I need:
Some way to check Fuel PSI (perhaps a RRFPR with a gauge built in?)
Some way to check AFR (is is 100% needed to get a wideband?)
Some way to monitor boost (a boost gauge...lulz)
Ensure I have proper plugs for necessary heat range (wanna suggest a P/N?)
Do I need to get a larger set of injectors? A Wideband? A gun to shoot my foot for buying a headache which may or may not ever make me smile? I love the potential this car has. Given the list of mods it has and all the parts, it could be a very fulfilling project, I just need someone to calmly spoonfeed me.
Not intending to bribe here, just trying to show I do not want to rob someone for knowledge I don't deserve due to lack of research. I bought this car, and it's my problem to figure out! However, If anyone who is friendly and experienced wants to lend a hand in teaching me in-depth, perhaps I have some sort of spare part in my collection that may appease you in reward? In example, I have a 13-button OBC with the stalk, it is untested and the obc has no pigtail, but it's something I'd like to pass on to someone if they have the patience to help me figure this thing out.
