Author Topic: 310R Input&Output Shaft Seals  (Read 1958 times)
gusgriff
« on: June 02, 2012, 12:05:36 PM »
Any suggestions on replacing the auto trans input and output shaft seal. My seal/bearing puller seem to big and I do not think a pilot bearing puller will work.
keflaman
  • -Receive: 35
« Reply #1 on: June 02, 2012, 12:44:13 PM »
I normally just use an awl to punch two small holes 180 degrees from each other, thread a wood screw in each hole just enough to get a bite and then pull on the screws to remove the seal.
You can also use a small screwdriver to lift the seal out, but I don't know how much room you have to work with on the input seal.
I use either method, just be careful not to score the seal bore.
gusgriff
« Reply #2 on: June 02, 2012, 01:37:05 PM »
Thanks
