DISCUSSION
Engine + Driveline
Which coolant sensor sends signal to DME?
Topic: Which coolant sensor sends signal to DME? (Read 2298 times)
Petebee
June 01, 2012, 08:26:57 AM »
We have two coolant sensors on the M42 cars. I believe the coolant sensor towards the front of the head (closer to the fan) sends the temperature signal to the temp gauge. I think the one towards the middle of the head (buried under the intake) sends the temperature signal to the DME.
Can someone confirm that I have this right? I plan to replace the DME sensor but want to make sure I get the correct part.
Thanks!
av8drvr
June 01, 2012, 09:41:39 AM »
I think you have at turned around, as my CTS closest to the fan failed and i had CEL, no problems with the gauge. I replaced that CTS and have had no problems since.
1991 318is
1996 Disco 1
Petebee
June 01, 2012, 10:28:05 AM »
Okay cool...what symptoms where you having? I am having overall crappy performance and tough restarts once engine is hot.
DISCUSSION
Engine + Driveline
