Author Topic: Swaping the basic overhead check panel to the one with more options  (Read 2629 times)
codyb
I have a 91 318i sedan. It just has the basic overhead check panel, pretty much does nothing.
I would really like to install the one with more options that monitors your brake lights, etc. Would the wiring harness already be in place under the headliner?
« Reply #1 on: June 01, 2012, 01:09:12 AM »
Sadly, it is not possible to install the nice check panel & have it be functional without a ton of work. The main chassis harness needs all sorts of splices, and relay boxes installed i various places. I looked pretty far into this years ago, and the easiest way (I use the word loosely) would be to pull the entire chassis harness from a 325e/i and swap that into your 318.
« Reply #2 on: June 01, 2012, 07:22:06 AM »
+1 on that.  And you'd never have the oil level functionality either - no float on our motors.
I always thought that'd be a great place to install a charging cradle for my smartphone though, or a Garmin GPS with an external antenna.
