Author Topic: A/C diagnosis?  (Read 2255 times)
bstarr3
A/C diagnosis?
« on: May 26, 2012, 12:14:27 PM »
I have a 91 318i.  It came to me without an ac belt, which didn't especially bother me since we have a nice mild summer up here in Oregon.  But now, it turns out that I'm moving to Albuquerque in June.  Different story!  One of my priorities is getting the AC working decently so that I can drive my E30 daily without wanting to die.
So, obviously the first thing I have to do is put on a new ac belt.  Beyond that, how do I test/diagnose problems?  If it blows cold straight away, that's obviously problem solved.  But unlikely given my car's maintenance history.  Is this something that needs to be gone over by a mechanic to know if there are problems?  Should I just try recharging it with some Freeze12 or duracool and see what happens?  R134 retrofit?   DIY or spring for a shop to do it? Any cheap parts I can/should replace?
Basically I don't want to throw good money after bad, I just want to get the system up and running.  What is a good algorithmic way to assess the AC and fix only what needs to be fixed as cheaply as possible?
Thanks
A/C diagnosis?
« Reply #1 on: May 26, 2012, 12:28:29 PM »
First you need to figure out of it was already converted to R134. If it wasn't and you can still find R12 somewhere, just use that as it works better than R134 (although it is terrible for the atmosphere). Otherwise, I would just see about having a shop evacuate the system & recharge it fully. That way, it would be good for years to come. You may also be able to rent the vacuum pump and pressure gauges to DIY the whole thing.
DeepMidWicket
A/C diagnosis?
« Reply #2 on: September 28, 2012, 07:17:17 AM »
if the belts been taken of 98% chance the a/c compressor has seized.
