Author Topic: WTB: A/C idler pulley bracket/tensioner  (Read 3156 times)
toddz69
« on: May 22, 2012, 12:46:44 AM »
I need the small, triangular-shaped bracket that the a/c idler pulley bolts to.  It also has another bolt in it that is then used to tension the idler pulley.  The bolt hole for the idler pulley is stripped out in mine. '91 318is.
Thanks,
Todd Z.
sfinsf
« Reply #1 on: June 26, 2012, 10:18:46 AM »
Quote from: toddz69;112696
Thanks,
Todd Z.
can you provide the realOEM image or part #, I may have what you are after, that is if your still looking. Is it #2 in the image?
91\' 318is
89\' 325i
