DISCUSSION
Engine + Driveline
air conditioner clutch
Topic: air conditioner clutch (Read 2325 times)
lqbanotxano
May 01, 2012, 08:36:34 AM »
Does anybody know where I can buy a new air conditioner compressor clutch?
My compressor seems to be doing fine but the clutch sometimes slips. I am trying to fix it on the cheap.
1993 318is 5sp / gen 3 Mustang injectors / Mark D 91/7000RPM / Z3 shifter / Ford O2 Sensor
colin86325
Hero Member
-Receive: 15
May 02, 2012, 07:46:06 AM »
I googled "Denso 10pa17c clutch" and came across this link. Make sure you get the right size pulley and v-belt or serpentine belt style.
http://www.apairinc.com/iView.asp?Cat=Clutches&Scat=Denso/Nippondenso
Marauder42
May 04, 2012, 11:46:34 PM »
Are you sure it's the clutch? I thought my clutch was out cause the car would start squealing when I'd turn on the AC and no cold air was coming out the vents. I replaced the belt and... Voila! Problem solved.
DISCUSSION
Engine + Driveline
